CLIFF 3.0 / 27 speed
Moderator: ccshop, LA-Group
โพสต์ โดย ccshop » 15 ธ.ค. 2015, 15:04
MOUNTAIN BIKE
CLIFF 3.0 is a new MTB X-country designed for MTB enthusiasts riders having a regular practice on all types of terrain, and looking for some performances.
A X-Country mountain bike reliable and performant with aluminium frame, hydraulic disc brakes and 100mm front fork travel.
Advantages:
1) Lightweight
– Light weight frame 100% aluminium tubes.
– Lighter than steel frames, it will help you to ride longer with less effort
– Lighter than other frames because we use the “triple butted technology” mean 3 different thickness in one tube to save material and weight where is no needs
2) Comfort
– 100mm front travel fork with Mechanical lock for more performance
– Upper position with a maximum of 45 degrees on you top body with the help of a 20mm rise handlebar and a 10 degree stem angle
3) Precision
– Shimano rear derailleur XT and hydraulic disc brake for the best shifting and braking performance
4) Efficiency
– 650B wheelset size are the best compromise for the best performance : Fast rolling and agile frame with moderate additional weight
5) Equiped ready
– Frame and fork ready to have fenders, rear carrier or quick stand
6) Sizes:
– 2 sizes: S (155-169cm), M(166-180 cm)
DESCRIPTION
FRAME: 27.5″ aluminium 6061 T4T6 frame light weight series, with a sport but comfort geometry
FORK: 100mm travel with aluminium crown, 28.6mm stanchion and one piece aluminium legs
Adjustable preload and mechanical lockout to increase your performance blocking the suspension when no need during up hill or on flat and smooth tracks
GEARS: Shimano gear system 27 speed XT/Altus and Rapidfire shifters Altus for the best ergonomics and shifting performance
CRANK: PROLINE aluminium crank 44/32/22t, 170mm
CASSETTE: Shimano HG200 9 speed, 11/32t
BRAKES: Clarks M2 light weight hydraulic High-end performance brakes, Easy maintenance and easy adjustment.
This brake offers a great power and progressivity to easily pass through technical tracks
HANDLEBAR: PROLINE oversize aluminium handlebar, 680mm wide and 20mm rise.
Shape studied to have a better position and keep control of your bike in all path…
STEM: PROLINE aluminium stem oversize, 70mm length and 10 degree rise
Short and oversize stem to have a precise control of your front wheel
HEADSET: Semi integrated aluminium headset
Cartridge type bearing are inside the head tube for better stifness and protection about water and dust
SEAT POST: PROLINE aluminium seat post in 27,2mm
27,2mm diameter to keep a flex and confort during your ride.
SADDLE: PROLINE saddle 272x133mm, narrow to help for pedaling and move easily on the bike but with comfort foam
WHEELSET: Double wall 650B rims, with stainless spokes and aluminium disc hubs
Double wall rims are stronger than single wall to help you to pass with no damages all kind of tracks
TIRES: Kenda, 27.5×1.95, 22tpi
Designed for typical mountain bike riding on dirt or rocks!
Reflective line for safety in case you want to use on the road
https://www.facebook.com/CultureCycliste
http://www.culturecycliste.com
Wire-less Rd.Tel.02-6514114
Sai4 Phutthamonthon Tel.02-4042185
Re: CLIFF 3.0 / 27 speed
โพสต์ โดย ccshop » 15 ธ.ค. 2015, 15:10
ราคา 12,xxx บาท
